Mopar85
What is a good distance for electric fans to be from the radiator inside of a shroud? I have very limited space from the rad to the water pump 2.5 inches! there is about 3" from rad to belts and pulleys so I have 2 electric fans so the motors are offset from the water pump. would 1" thick shroud be sufficient?
That is about all the room I have when i make it.
