I am in the process of swapping the 360 LA in my 70 Dart to a 360 Magnum (using either an Edelbrock or Holley 750cfm carb) and keeping the Magnum front end, so I am trying to figure out the details for an electric pump. My car still has the stock gas tank and pickup in it. I have read through quite a few of the threads on here and wanted to see if I have it right...
I am thinking of buying either the Summit Streep & Strip Fuel Pump and Regulator (SUM-G3136-2) kit or the Holley Blue Kit... Any recommendations for or against either of these?
As far as mounting goes, I need to go as close to the tank as possible and mount the pump below it. Will I be able to run a return from the pump using the kits I am looking at?
Also, should I stick with the stock hard fuel line that runs to the front of the car, or should I look at replacing it?
Lastly, whoever owned the car before me installed an aftermarket fuel gauge that doesn't work. Any quick ideas for troubleshooting this while I am working on the fuel pump.
Thanks in advance for the help! I have been reading the forums a lot but this is my first real post.
