silver fox
I replaced the old holley pump with a new summit pump & reg. hooked up test for leak's pump worked great no leak's but flow's straight into the carb as if the float's stuck open so I shut it down the car has been sitting for a year so i'll check to see if the float's will loosen up if not what else would it be thank's
