berry-cuda
Next your going to need to take apart the equinox column you well need the motor off it, input coupler and mount from the column, see pic where to cut the larger Od of the equinox tube fits inside the mopar steering column perfectly so I cut it at the largest part and hammer the inner flange in which is part of the equinox collapseible column then weld from inside then I drilled holes in the dodge column spot welded the mount in there, I wouldn’t weld it until you set it all up and have the clocking of the eps motor where you want it
