7dswinger
MOPAR's rule
So my engine bay looks like a rats nest and I've finally decided to take care of it as I can even start my car any more due to a bad battery and possibly a bad alternator, getting 10v of charge at the battery and it drops as it runs
I've got to pull allot of stuff out as it's not being used and replace allot of stuff as well. For example I've got the MP orange ignition box in there but I'm running a 6A box so it's unused, I'm just not sure where to start on this as it's a bit over my head. Any tips on how I should get the factory harness apart so I can deal with it?
The other question I have is having to do with the ignition. I've got an MSD 6A box, E-Curve and Blaster SS coil (which I'm still waiting to here from MSD if it's compatible with the E-Curve). In the wiring diagram there's a brown wire that runs from one side of the ballast resister to the positive side of the ignition coil, currently I don't have this hooked up to the coil. Should I hook this up to the coil.
The other thing I'm wondering is that this thing is. I believe there's a wire running from the ballast resister to it as well, I just can't figure out what it's for and if I need it still. It's on the passenger side.
Here's a small part of the mess I'm dealing with:
