Any of you early "A" Body guys pull the engine compartment side of the bulkhead connector loose? Thanks
I have several times. Search (from google is best). Can only work for 1964, not for later cars that had 3 connectors (I'm not sure about 1966). They can do similar by doing the "fleet bypass", which is much discussed here.BillGrissom can you post a picture of the "dedicated lugs" for the main power wires that you mentioned? Sounds like just the fix for this long time problem for other years of Chrysler products...
