bmaudlin
Installed new bulbs and holders into the rally dash on my 70 Dart.....installed the dash back into dash frame, turned on the lights and I seem to only have some dash lights around the speedometer, not the tach or other gauges. All grounds seem to be in place and I can't believe I have that many bad bulbs or bulb holders! Any suggestions?
Also attempting to start the vehicle with an aftermarket electronic ignition. I seem to have spark when the key is turned on.....there is a spark when the coil wire is grounded as the key is turned on, but no spark when the starter is engaged. Have checked all the wiring and it seems wired correctly. One other note.....when cranking the tach needle seems to be going to the negative side of the gauge! Again the tach wiring seems to be connected correctly.
I know a lot to ask without seeing, but any possible suggestions or helps would be appreciated. Thanks, Ben.
