69valiant21
Is there a good source for electrical schematics? I dont see a sticky for them, figured it would be a sticky.
I'm sure each car has its own. what car do you have? That's going to help people. You know they made a lot of cards right? And they had different wiring....Is there a good source for electrical schematics? I dont see a sticky for them, figured it would be a sticky.
You would think that wouldn't you? Well I can say that they are very similar, but they're not going to be the same. You can definitely not take one out and put one into another. As far as one year to the next or one model to the next.I would assume the ignition circuits, lighting circuits, etc etc would all be pretty similar between A-bodies?
Its a 69 Valiant.
Please give me a little bit more credit than that! I looked it up first, And then had them look up what I looked up and made sure they had what I looked up and then I asked them to print it.Luckily I have a plotter at work, just need the schematic. So they just googled it and you trusted them to pull up the right one?
Some of the schematics at mymopar site are not 100% correct. Just be careful when using them as info.
If you can get a service manual schematic, those are better.
I have the schematics in front of me. PM me to let me know if you want me to scan them in for you. It may take a day or twoLuckily I have a plotter at work, just need the schematic. So they just googled it and you trusted them to pull up the right one?
