My son put a new alt today now I have 15 volts going to the battery I have ground strap missing.So I will be adding a new one tomorrow.
Good news Cliff! Ground cable or ground strap?? If its a ground strap, you could use spare wire if its a decent size maybe??
Yeah I know so I have a new ground strap to add which should give me 2you should have 13.8 to 14.2 . 15 volts is high . that ground strap is essential.
i see , you have one already. thats good. you should read through that thread if you get time. Del helped me nail it down.Yeah I know so I have a new ground strap to add which should give me 2
whats cool is that thread is almost 14 months old and i have not touched my charging system , it is still working perfect.I will thanks Lance
im always home lolYou going to be home tomorrow?
i will try to remember lolPhone?
*note to self* *phone home * not ET
email me in the morning :blob:
ok sounds good. i hope all goes well with that Cliff. let me know when you get home.I will after I get home from the Doctor.
My voltage regulator did a melt down yesterday, my son put on a new voltage regulator,new alternator belt since the old one was stretched so far out there was no adjustment. I left to go pick up my son a little while ago everything was nice and bright. When I stopped outside the building where he was at I noticed everything got dim and so did the engine (this kept cycling like this until it was under load). The belt was tighten properly nice and tight with about a 1/4 in play in it. Any idea's of what it could be?
Thats pretty common with old Mopars. They dont charge well at idle. You can upgrade to a GM alt or later Chrysler Denso style alt. Also bypassing the ammeter gauge helps.
http://www.madelectrical.com/electricaltech/amp-gauges.shtml
OTR you should not have the "ammeter bypass" problem. According to my '74 book (in which the wiring is considerably more complicated than earlier models) your ammeter wires should ALREADY be coming out of the firewall in a separate grommet from the bulkhead connector.
THIS DOES NOT, however, cure the problem of voltage drop through the ignition harness
Steve FABO is my home the other site you just posted really isn't for tech support
