I'm too lazy for all that. lolPost its help also, just dont scroll up.
Check the build date . Might be an early build .According to Chrysler literature in 1972 Abodies with 318 engines could come with or without electronic ignition.
a few did a few dist for them usually early productions. Big money cores and extremely hard to find.I also thought 72 was 1st year for entire lineup . Did not realize it was optional on some. Mopar literature is a bit ambiguous.
Check out this page… says it’s std on 72 440-6 ! I wonder how many 72 440-6 cars were made ?
Okay, you say it was already electronic ignition when you got it- let's see a picture of the distributor that WAS in it. I have a sneaking hunch it was an MSD RTR or Fleabay Skip White all-in-one distributor (one wire hookup), and all the connectors for the factory ECU, distributor, and ballast were removed from the harness.On the advice from a buddy, I purchased an Electronic Conversion Kit, I guess as an upgrade. I have a few questions, but will just start with this.. My car was already electronic ignition, although not running when purchased.
This is the only "box" (photo attached) my car has and the plug comes right out of the harness. (2 prong). The original distributor in the car has the 2 plug wires coming out but I can't find in the harness or anywhere else it plugs into. Does that distributor plug go to another box that is just missing from the car..? View attachment 1716342765View attachment 1716342766
If you don't have this already, you need it. Very easy to wire up. Comes with deestruckshuns.This is the only "box" (photo attached) my car has and the plug comes right out of the harness. (2 prong). The original distributor in the car has the 2 plug wires coming out but I can't find in the harness or anywhere else it plugs into. Does that distributor plug go to another box that is just missing from the car..? View attachment 1716342765View attachment 1716342766
Didn't it come with this...............The kit I bought obviously has one,
That's a nice copy of the older MP instructions.
here's a single resistor (points setup) on '70 or '71.A conversion can be done a little simpler since the newer ECU's don't need the 5 ohm resistors.
You got a link to them piggyback doohickeys?here's a single resistor (points setup) on '70 or '71.
The OP's '72 Demon looks to have the resistor mount hole above the lip. But if there is a mounting hole below, that's the better location in terms of keeping it dry.
1. Mount a new or used 0.5 Ohm resistor. Not 5 Ohm. Not 1.5 Ohm. 0.7 Ohm is OK.
2. Disconnect points distributor at coil negative.
3. Install magnetic pickup distributor.
Side note: Preferably one with a Chrysler performance advance curve (non-smog). If you don't know, then best to do a quick and dirty check on the bench. Plenty of posts on FABO about identifying the Mopar vs Mallory vs Delco type internals. A few posts with tips on how to get some idea of the advance on the bench.
4. Observe the wire positions on the 5 sided plug. Write down the colors relative to position. Position matters.
Top of the pentagon is the power connection (light blue in diagram below). Join this to the to the ignition run wire (J2-dark blue or dark blue with stripe).
Do this as follows:
Route the ECU power wire alongside the factory wire harness and then to the ballast resistor.
Install an insulated 1/4" push-on terminal to the ECU power wire.
Install a piggy back onto the ballast resistor post where the J2 (Blue) wire(s) get attached. (arrow on diagram above).
View attachment 1716342906 <= Piggyback allows installation of two female terminals onto one male terminal.
5. Identify the wire on the ECU plug to the left of the power. That's the connection to coil negative. It connects to ground instead of the points.
Route that along the wire harness so its supported and protected. Install the appriate size ring terminal and attach to the coil negative post.
6. Route the ECU distributor wires to the distributor plug and connect.
No. I have a handful in the box I have no idea now where or when I bought them.You got a link to them piggyback doohickeys?
Thank you!.250 Tab M to FM to M Piggyback - WiringProducts, Ltd.
.250 Tab Male to Female/Male to Male Piggybackwiringproducts.com
and KrazyKuda's has more links here
"Piggy Back" Fuse available for Glass Fuse?
I would like to know if a company manufactures (or anyone clever has fabricated) a way to piggyback onto an old style glass fuse? I just want to tap into the instrument/dash panel illumination so that my aftermarket oil pressure gauge can be read after dark. I just don't like splicing into...www.forabodiesonly.com
