- Joined
- Apr 18, 2009
- Messages
- 4,310
- Reaction score
- 4,901
Since I have found out that wire coming out of the harness for the electronic speedo signal from hotwireauto isn't truly a speed signal I have decided to go with a gps sender, intelletronix.com for a few reasons.
1. My speedo counts mileage with the engine running, doesnt matter if the car is moving.
2. Speedo will jump if goosed when in park and neutral.
3. This is a simple 3-4 wire hook up and does not care what tire size or gearing I have.
4. This was not nearly as pricey as all the others I looked at.
I will post up how it goes in and how quick it is to registor and the accuracy when I get it, which should be this afternoon. So anybody that has a wiring harness and using the 545rfe trans, take a look.
