Many of you may recall that my son Aaron and I have been rebuilding his 74 Dart Sport over the past three years after it was totalled his last year in college. We swapped in a 360 for the original slant six and kept all the old wiring harnesses. For the past couple of months, while doing all the last few things to get it road ready, we have been driving it a bit around locally, and it has been running great. We finally drove it to town last week (about 20 miles round trip through town with plenty of stops) and had no hint of trouble. Monday, I drove it to a meeting about two miles from home to show it off. After the meeting, it started fine as usual, idled perfectly, and had crisp throttle response, for about 10 minutes of oohs and aaahs. On the way home, I took my sweet time toodling through the two stop lights in town and eased over the RR tracks. As I started to come off the back side of the tracks, the engine died instantly. No stumble, no stutter, no hesitation first - just dead as a hammer, like I had turned off the key. I rolled into a parking lot and that was it. Holley 750 was getting plenty of fuel at 7 psi, Chrysler mini starter was cranking strong, and there were no apparent wires melted by the headers. Nothing I did would get it started again, so a tow from the wife was in order. Got it home and pushed it back in the garage where it sat untouched until last night. On a lark, I thought I would give it a try and it popped right off, first turn of the key! :wack:
I am bummed out in a major way. My 40th high school reunion is tomorrow evening and I was looking forward to driving the Dart there. Now I have absolutely no confidence that I'd either get there or make it back home.
A few things I checked last night:
Battery
12.68V off
13.54V running
12.70V running w/ lights on
Ballast resistor
2.2 ohm primary
6.1 ohm secondary
ECU pin 5 has continuity to ground
ECU has extra ground wire case to fender
Any ideas are certainly welcome. Let the games begin.
Battery
12.68V off
13.54V running
Ballast resistor
2.2 ohm primary
6.1 ohm secondary
