stumblinhorse
Stock’ish 69 318. Converted to mopar style electronic ignition couple years back. Summit racing brand. Ballast resistor still in place. Engine been running fine for a couple thousand miles on the electronic setup. It just started in the last day, to die driving down the road. I turn the key off then hit start it starts right back up and runs for remainder of the drive. Done it a couple times now.
Figured the ecu is going out? But not seen one “reset” and work fine.
Second question is it worth the extra couple hundred bucks to go to a MSD box or just buy a summit brand orange ecu? in a stock’ish 318?
thanks for any help!
