winstoninwisc
Taint easy livin free,season ticket ona 1wayride
hey all I just got my 360+ build done and in , first shake down run today , I have a new tsi trans with a 3200 stall that doesn't seen to be stalling ?? I have a m1 intake , mechanical msd , 525 lift 309/288 comp cam with a 650 dp/df mechanical secondairies.
2 and 3 rd gear are awesome in the sweet spots , but I cannot get it to come out of the hole I am running the timing at 10 initial and 37 , we changed the springs in the distributor to the lightest and changed the shim weight to the red as recommended by MSD to open as fast as possible I am wondering by the CDI x rpm 3456 equation for cfm in carb size if I am way under carbureted , wich the build called for a 780 cfrm vacuum secondairies or where am I missing my tunning at ?? this got way over my head with so many varyations , I just wanted to get some better experience to see what they think and what they figure the cfm<s should be on the carb .
Rick , tony , ROB , Fishy , MRL, BRIAN Hilfigar can you guys give me a little insight to what might be going on here .is there a way to check or set my stall?? it doesn't seem to let me buzz, 3000 it comes in and smak second and its on a tear , please help me you guys not all named with great trouble shooting experience . thanx HOPE YOU CAN READ THIS pm asap
also I have rhs 2.02 heads and plugs gapped at 45 running on 91 0ct
