I have a 408 stroker backed with a 727 that is making some noise. Noise is very faint at idle in park. When put in gear at idle with the parking brake or brakes on it is the loudest. Oil pressure cold is 60 at idle and 15-20 hot at idle. Cruising is around 40-45psi. After I drive for awhile make a few hard pulls cruising is around 35psi-40psi and stays at 35-40psi wot. No weird noises driving just at idle, I have checked converter bolts and They were tight. Is there a way to upload a video?
