Going to drop an engine out the bottom using a 2 post lift. With all that engine/k frame weight coming off the front, do we need to worry about the car becoming tail heavy and tipping backwards?
Thisstrap it to the lift
How many times have we watched graveyard cars do this exact same thing with no problems?
I'd be worried about that. If I were doing it that way, I'd try to set the car a little farther forward then I normally would. Then, I would make sure not to lift the car any higher then I absolutely had to.
Personally, I just use a cherry picker with some 1/4" angle iron bolted to the bumper bracket holes. It works perfectly.
@burdar have you got pics of how you stabilized the arse end?
Thanks, looks nice!
