SameDoes it matter which trans crossmember you are using? Are 6 cyl and v8 all the same?
If your '69 big block handles like a pig you built it wrong for handling. With modern tires and shocks, added sway bar and bigger torsion bars these cars can handle well with a big block. And, quite frankly, if you don't do the same thing with the slant, it will still handle like a pig...
383/4sp
Nah - Its about compared to what you compare it against. I was referring to like vehicles built to carve roads like M3 Bimmers or M5s I have owned and driven. Yeah I got double adjustable shocks, sway bars, bigger torsion bars, heavier springs four wheel disc and all that jazz - and yes the car does well for what it is but its still a pig. I love it which is why I keep dumping money in it and have owned it since I was 15.
The 69 does fine for what it is BUT reality is when you take a car like the 69 Dart and throw a big block in it and have to connect the unibody etc and start with a 57/33 weight distribution its will only handle so well. The car was manufactured crooked for chrissakes. Which is why in stock elimator and many types of racing enthusiasts correct the geometry of the drivetrain.
So how can you tilt the engine back this far with the trans bolted up and mounted to the trans crossmember correctly?FWIW on the engine height - my engine sits high in the front on a pair of elephant ears. If the K-frame isn't cut for the oil pump, it's necessary for the front to be higher than level.
Mine's up so high there's room to fit a finger in between the oil pump and the K-frame mounting bracket. Maybe that's a little bit too much I guess but it's the way it came to me. Planning to change engines, and if it stays B/RB I will use a TransDapt kit so it bolts to the K-frame (after cutting for the oil pump)
You can kind of see it here - the camera was level with the fender.
