Engine stand.
Snake
Mopar Nut
Belleville Canada
Ok the engine stand from hell,witch way does the main post go ,in the first pic the lower bolt is in the rear,can you see there is an angle cut at the bottom,or the second pic,the bolt is in front and the angle is ,what looks right.If any of you remember how it leaned,too far for down my liking.
no need to go all the way to 8 - 3's or 5's are fine - in fact, I am fairly sure the ones I use aren't even automotive grade...
I know mine are not as I use all thread and nuts because the two bottom holes on the block I like to use are not threaded. :D
