fishy68
Tyr Fryr's Inc.
Does anyone here know if the engine to trans. torque bracket (drivers side) is the same for a 904 and 727 trans?
I have a bunch of those brackets if you know the length you need.....
Thanks, Mark
not to hi-jack but can anyone post a pic of this brace and it's location because there wasn't any brace on my 318 when I pulled it and don't have one on my 410 which could sure use some sort of torque brace, I was looking at one of the dampened torque straps being sold as a way one reinforcing the drivers side mount but they mount up front behind the PS pump ,something for the back by the tranny sounds like a welcome addition
Thanks, Mark
......................I'm not positive, but i think they r not the same.................kim...........
I'm already planning on going to the Schumaker mounts ,and I think thats where I saw the dampened torque strap , when I got the car back I found the lower starter bolt 1/2 out and the block to bell housing bolt that is tucked in above the starter { the "impossible bolt" as I call it } was missing so I am now trying to brace and secure this thing every way I can come up with LOL .
I used the pass. side one from a 73 318 on my 77 360,the d.side would,nt fit.So I,m gonna do the weld/cut/weld thing to it and make it fit(d.side)Just another winter project while the car sits idle.Thanks for the reminder Tracy.
I have one of Brians 410s so its a 360 block going to 904 now
Shouldn't be a problem.....I must have 50-60 of those things on a shelf but I'll go through them tomorrow and separate them out and see if one of mine matches the length you need.Mark I did my best to get a measurement but with the odd shape it's pretty hard to get an exact measurement but I'd call it 10-3/4". I had the right bracket for the early style originally but needed the longer one for my 79 engine that was in the car and welded an extension on it. I took a pic and attached it to show the orientation of it when I measured it. Let me know if you have one. Thanks, Tracy
Thanks I have Eddie on speed dial LOL , my phone pocket dialed him for a 15 minute call one day tying up his phone in the process I'll give him a call and see if he still has it .Ok. You'll probably need a different one than I do. Barracudakid PM'd me that he has one for a 904 trans. You might do a search for him and PM him. Or if your an e-Bayer I saw a couple sets on there for 904 transmissions for about $25.
....................................................................................................Your welcome and good luck with the project
Here's the two versions I have of the short, driver side, braces. The one without the heat shield is the earlier of the two.
