Engine weights
pittsburghracer
Freeport, PA.
Saw this on Facebook and thought someone may be interested
Why is it so hard for me to believe a slant 6 only weighs 475lbs?
Do you know what a aluminum 426 hemi head weights vs a iron one?
Big block dart had a write up years ago, it was roughly a 30-35 pound savings per head.
I do know from shipping, that a BB 452 head weighs 52 pounds and an BB Eddy RPM head weighs 28 pounds. with the hemi head being a bit wider,
cast crank in 360 wights less than forged 340 carnk......360 pistons are lighter then 340 pistons....
You are much smarter than I am so I’ll take your word for it and I’m sure you’ve actually weighed them. It just made so much sense in my head that a cast, externally balanced crank with larger main journals would weigh more.
Thanks for this, buddy. I am saving this chart and am going to add it to the How To section. Compliments of you of course.
Maybe you've wrestled with trying to stand one upright against the front bed of a truck before? Lol they are awkwardly shaped @475lbs.
I watched my brother who's 225lbs struggle and almost hurt himself doing it. Lol thing kept slipping and spinning around and wanting to land on his foot or leg.
They'll put the hurt on you if you let um. lol
What surprises me is that the old 392 hemi is lighter than a 426 hemi? The DC Engine book says it's the other way around...
These weights seem odd to me, already alluded to in post #13. Then I look again & see more anomalies...
Dodge 241 Poly is 65 lb heavier than a 241 Hemi?
276 DeSoto Poly is 45 lb heavier than a 276 Hemi?
