69Elcamino
Member
Brought a rat 69 el camino with a 360 in it need any ideas for hooking up the wiring from gm to the 360 block to get ignition to work
Any idea where or who has one cheapPut a HEI unit in it. One wire from the ignition... done
Cool thanks for the heads up and my hei will be here TuesdayYes a relay would would work and no it does not go dead in the "start" position on a GM. They use a second wire up from the starter solenoid to give the coil full battery voltage in the start position.
Ok my resistance wire stays hotCome to think of it you could still put the wire on coming from the starter back on. Should not make any difference.
Nope el camino is the same mine is hot all the timeI ended up with the car because it did not run right. Someone else put the HEI in it and just reused the resistance wire. All I did was cut off the wire coming up from the starter. Then pulled the bulkhead, cut the resistance wire out and ran my own. It stayed hot on that car. Maybe an El Camino is different? IDK
