Just like the title says....the key does nothing. ..I don't even hear the relay click...but I can jump the relay and it turns over....
Where should I look?
Jeff
Jeff
Ok...it starts if I jump it, but with my girlfriend in the car holding the brake, it wants to move ....it's NOT going into park.
How do I properly adjust that linkage?
I've googled it high and low and all I find is how to adjust the kickdown linkage. ..not the shift linkage. ..
Jeff
There is the lever coming off the shifter, then a connecting rod, then the lever on the trans.....
Should the lever on t he trans be all the way forward towards the front of the car?
Jeff
I got to leave or I'd post pictures.... Is there a member close by that can give Jeff a hand???
And park is all the way towards the front of the car - yes?jack up the car with her in it. Have her move the shifter to park, then drive so you can see where the positions are. Then put the trans in neutral, then have her line up the mark with "N" on the shifter and tighten the slide adjustment on the linkage...
Then make sure that it can get into the full range of the gears from Park to 1.... If not adjust as needed...
Column shifterJeff, do you have column shift or console???
Awesome!
Awesome!
I'll try again. ...I can NOT seem to find park....???
Jeff
Park is all the way to the rear...
loosen the slide on the linkage and manually move the shift lever to the farthest rearward position, that should be park...
Or go all the way forward with the shift lever - that's first gear, then click through 2-D-then go to N... Set the shifter in the car to N and tighten nut on shift linkage, then verify by moving the shifter through all of the gears...
Lol.....there's an answer in there somewhere. ....!Jeff, do we need to put a little hair on it so you can find the spot. I know bad joke while your frustrated
