68 Rat Rod
When I turn the ignition switch to start position I just get a click out of the starter relay. I can get the engine to turn over if I Jump the relay. My question: Is the relay good if it clicks when key is turned to start position? Maybe my neutral safty switch is out of adjustment. What is your thought?
