99CENTS Well-Known Member Joined Feb 1, 2012 Messages 143 Reaction score 37 Location PA Feb 5, 2012 #1 Will the newer magium motors work in 1967 up with dakota mounts. Or is there a mount made for this swap
funwithfuel Well-Known Member Joined Jun 27, 2011 Messages 521 Reaction score 50 Location Wilmington Il Feb 5, 2012 #2 The magnum engines have the same motor mount "ears" cast in the block as the LA's allowingthem to be backward compatible. You'll need the mount brackets and insulators for the K-frame you are using.
99CENTS Well-Known Member Joined Feb 1, 2012 Messages 143 Reaction score 37 Location PA Feb 5, 2012 #3 Thanks. After futher looking i seen that
