INhondo
Member
Via Google I found out some information on the above camshaft but no cam card. LSA of 107 degrees. I'm going to rewatch David Vizard's You Tube video on Cam Cards are wrong to see what's what.
What video is that?Via Google I found out some information on the above camshaft but no cam card. LSA of 107 degrees. I'm going to rewatch David Vizard's You Tube video on Cam Cards are wrong to see what's what.
What video is that?
That’s just messed up ****I asked that and was told to go look it up.
Grind Number | Valve Lift 1.5 | Valve Lift 1.6 | Duration at .200" tappet lift | Duration at .050" tappet lift | Advertised Duration (at .020" lift) | Lobe Separation Angle | Opening at .050" tappet lift | Closing at .050" tappet lift |
HEV3945AS | INT .546" EXH .560" | INT .582" EXH .597" | 157 163 | 239 245 | 270 277 | 107 | 15.5 BTC 52.5 BBC | 43.5 ABC 12.5 ATC |
No installed centerline in my old Hughes catalog.If I had to guess it would be 104 or 105.Those smarter than me will chime in.Listed as tight lash 10 Intake 12 Exhaust.
Engle ground hughes cams to his specs, he won’t know about engles propriety cams. He told me he would not grind me a Hughes cam as it was Hughes propriety grind. engles cams were half the price of hughes cams. This was about 20 years ago.I saw a post somewhere online that Hughes sold some Engle grinds. Maybe they can give you some info?
I would have posted a link if I knew how to, computer dumb *** here. But there is a wealth of other information in other videos on his channel not to mention the books he has written. Truely good reads.That’s just messed up ****
Thanks brother!
I believe Engle for a long time made all the cams for Hughes. So, yes all the cams they had were Engle that said Hughes on the boxI saw a post somewhere online that Hughes sold some Engle grinds. Maybe they can give you some info?
DV is more talking about LSA which is a different matter to ICL. DV's formula indicates the starting point for the LSA for best torque across the RPM range. This uses the displacement of one cylinder and the effective valve seat diameter (intake valve diameter × 0.91). ICL is a matter of whether the cam is installed straight up, advanced or retarded.Call Engle and tell him that you don’t have a cam card for that particular cam. He will know what it is. What you are looking for is the intake lobe center line. That is how you install it. He will be able to give you more information on that cam if you ask.
The DV YouTube video talks about ICL, which is correct for your displacement and intake valve size and how this may not match your cam card ICL. There are about 4-5 cam videos on David Vizard’s YouTube channel, they are not hard to find.
Depends on the grinder and how much advance they build in, but most street applications respond well to 5° advance.I guess I'm a little slow in my thinking. I sent this to Hughes and they did contact me back and he said, "follow the cam card". "Stay off the Internet" when I mentioned installing @ 103-104 degrees and 104-105 degrees.
Grind Number Valve Lift 1.5 Valve Lift 1.6 Duration at .200"
tappet liftDuration at .050"
tappet liftAdvertised Duration
(at .020" lift)Lobe Separation Angle Opening at .050" tappet lift Closing at .050" tappet lift HEV3945AS INT .546"
EXH .560"INT .582"
EXH .597"157
163239
245270
277107 15.5 BTC
52.5 BBC43.5 ABC
12.5 ATC
Well, this looks a lot different than the cam card with an Erson Cam I have on hand. So, I'm guessing he's recommending installing @107 degrees. I'm going to start assembling this engine soon but I'm going to buy a true roller timing set with multiple keyways on the crankshaft pully to hedge my bets.
I used Engle for a long time before Dave sold them. At the start Dave had Engle make his cams. A product they allready produced. But after some period of mass marketing , Dave's hat got big. He told Engle he wanted to be "it" Period! (IE) If he continued to buy from Engle for his private label, he was it Period. In other words Engle would not be able to grind them for themself for sale to others.I saw a post somewhere online that Hughes sold some Engle grinds. Maybe they can give you some info?
