cwkerr007
I have a 00 5.9 that I put a set of eq heads and a new cam, tim chain, studs, guides,rol rok, and while trying to set my rocker geometry I see no way to get the roller on the valve stem and the rocker at the proper angle. when the rocker is at the correct angle of the 2 pins there are no threads for the stud. I'm thinking I got the wrong rockers from P.I.E. these are comp studs comp guides but some chinese crap rockers and I'm fixing to put the pedestal oem stuff on it it's a 512 480 lift comp magnum cam what should i do???
