Exhaust 1964 Barracuda
ryan1964
California
I'm am looking for these parts to fit the stock manifold so when I take it to the exhaust shop I don't get hug up waiting for them any help would be appreciated
Ok thank you I was reading through another post on this forum and someone said they had to wait for the shop to order them so I figured I would ask thank you
Most (well- many, anyway) exhaust shops flare the pipe themselves... I'd check with them first.
Tried that. All of them near me have said that They can't do the Flare and the Bend required at least on the Passenger-Side.
Forced me to use my Stock (Teeny Weenie)DownPipes with Adapters to my new 2" Dual Exhaust...
Still Looking for the Solution. Who even makes these?
I'm fine using the small down pipes that's what I'm looking to see if someone sells that part incase the muffler shop can't do it I have the old ones the passenger side leaks a little bit
Yeah, that's why I said to check with them first- most "exhaust shops" are just parts replacers now, order in the pipes and slap 'em on; and you're limited to what's in the catalog. Hell, I can do that myself.
The trick is to find an actual Exhaust Shop, that can bend and tweak whatever size pipe you want for whatever application you have- and that includes the flares. Desoto Firedome in an Omni? No problem...
For prefab downpipes check Tti's site. Exhaust_Parts
My shop is really good he should be able too but just in case I'd like to be prepared. And you're right most shops just slap **** together now
I bought a complete Waldron’s HiPo exhaust system to connect to my stock manifolds for my 65 Dart wagon. It has the flares on the Y pipe that fit perfectly to my manifolds. The system can be installed at home FWIW.
Accurate Exhaust is where I got my stuff. They have the complete reproduction 273 4bbl system for restoration purposes.
i just installed TTI headpipes and midsection w/ H pipe on my 65 dart with 4spd and they fit *perfectly*
** you need to mod the trans x-member if doing true duals
*** with the 90* filter adapter, depending on what you've got cooking mounts wise and filter housing wise you may need some adjustment. i shaved the bolt down a bit and put a tiny dimple in the pipe.
