superdart
Shade Tree Tinker Gnome.....
So, I'm installing TTI Shorty headers and extension pipes in my Dart....got tired of the long tubes dragging the ground. But I'm running into issues.
I bought the TTI linkage adapter for my column shifter to clear, and it works. However, it seems my kickdown linkage is set too far off the trans case. I can't connect the rod from the pivot arm to the kickdown lever. The trick is that I have an A-518 trans, and I think the guy that installed it reused my original 904 linkages.
Are there any differences in these parts between transmissions? I'll post some images a bit later to show the issue. I can probably cut/modify the pivot arm, but would to see if there is a proper setup before I go hacking on stuff.
