NiceFishEh
Hey Guys:
As I suspected, the heat riser in my 340 HP exhaust manifold is 90% closed and rusted solid.
Problem No.1
When I remove the front and rear manifold bolts, is coolant susposed to drain out thru the bolt holes? Please say yes!
Problem No. 2
The angled oil filter adapter needs to come out so the manifold will clear. What the hell size socket does it take? It's not 1 1/8 or 1 1/4. Can't buy a 1 3/16.
Problem No.3
The cast has a small crack where the pivot bar goes thru the heat riser. Is brazing the best way to repair it?
I want to remove the flap and bar portion inside the pipe and weld the rest solid so I don't have any holes to fill in. Please advise.
Problem No. 4
No manifold gasket!!! just that tin heat deflector. Should I chuck the deflector and just use the gasket or use both?
So much for a five minute job!!!
Thanks
Problem No.1
Problem No. 2
Problem No.3
Problem No. 4
Thanks
