Slantsix64
So yep my water pump decided to blow out, wtf?
A 4" spacer and a 7 blade fan? That could be an issue especially if the fan is out of balance.So yep my water pump decided to blow out, wtf?
LolThat's a Whole lotta spacing!
One of the problems I have been having also is that my square back alternator keeps hitting the magnum head so I had to grind some of the back alternator or else it would line up the belt crookedThe long spacer and out of balance fan blade metal fatigued the snout.
NO NEED of a spacer that long. My dart 273 2bbl runs fine all day long with the stock spacer and stock 7 blade fan, no shroud as it came from the factory.
As for early Cast iron or later Aluminum water pump. they are different in many ways.
- the inlet is on the wrong side
- the mounting bosses are not the same height for the alt etc.
- the overall length is longer so the fan belts will not line up correctly
so maybe the later water pump might actually help me with that because the later alternator would of came with that kind of style water pump?The long spacer and out of balance fan blade metal fatigued the snout.
So my 67 brackets won’t work with the 70 style water pump?Might.
But you will need all the correct pulleys and brakets.
Be thankful you're still alive ...you still have a face without massive trauma n scarring ...your hood doesn't have a hole in it... nobody else was hurt.So yep my water pump decided to blow out, wtf?
LolBe thankful you're still alive ...you still have a face without massive trauma n scarring ...your hood doesn't have a hole in it... nobody else was hurt.
It's not a cowbell my friend....
WAY too much spacer.
It might be a 6 1/2 inch crank pulley but good catch on the water pump pulley sizeBut I see you are running a tiny fan pulley, looks to be extremely small. My guess is that the ratio is something like 8 to 5=60 effing percent overdrive!
that means your pump is spinning 60%faster than the crank. And that means by 5000 crank rpm, the pump would be doing over 8000.
yes it’s the smaller diameter pulley, original to my car which came with factory 1967 AC, I might swap it out for the larger one think I have one in my shed I’ve had two bearings go out in my water pumps that also might be a reason why the engine isn’t stock and it revs up to 5200 rpms before I shift, this all happened when I was doing a burn out so ya this is good to knowI wonder what stewpot of parts I lucked into when I just screwed my stuff together.......
that means your pump is spinning 60% faster than the crank. And that means by 5000 crank rpm, the pump would be doing over 8000. It wouldn't take much of an imbalance to shake it apart.
I can't imagine why you would run it like that.
Are you having over-heat issues? Those are usually easy to solve.
Not that I know of pretty much everything is the same I just swapped the crank pulley to one with no extra groove for A/C which the water pump belt lined up correctly, the alignment issues with the alternator was years after I swapped to magnum headsWhen the AC was removed the wrong mix of parts was used.
Alan
We are in agreement. I did not look close enough at the crank pulley it does look like 8" and the wp pulley looks tiny.Well it looked bigger than the balancer which are usually 7 so I just guessed, as I stated
