Slantsix64
Thanks AlanThe correct 67 non-AC water pump pulley is 6-1/2" diameter and 2-3/4" tall, the fan spacer is 2-3/8"
Alan
Alan
A/j would I be okay to run a 6 1/4 crank pulley and a 6 inch water pump pulley?Well it looked bigger than the balancer which are usually 7 so I just guessed, as I stated.
That would be overdriving the water pump by a small amount, about 4%A/j would I be okay to run a 6 1/4 crank pulley and a 6 inch water pump pulley
Too much horsepower! LOLSo yep my water pump decided to blow out, wtf?
Gotta hate it when you bend your shaft.The fan clutch was out of round and therefore balance. Cracked 2 housings and bent one waterpump drive shaft.
LolGotta hate it when you bend your shaft.
