1973Kathleen
Active Member
Okay, So i have a 1973 Dodge Dart Sport 318 904 if that matters. I recently replaced my 318 with a 1968 318 with hooker headers on it. Everything was going well until we had to pull the steering column in order to dent the header so the car can turn right. After reinstalling the steering and the whole engine is back together and everything should be wired we decided to try and crank it. it was a no crank, so i lifted it up made sure the car was in park or neutral and tried to crank. we got nothing. then i decided to see if anything else worked i had no turn signals, horn, or cranking. I never had a horn but before this everything worked. We noticed that the steering column was really plugged in and when we plugged it in everything kinda went crazy. The car still doesnt crank. my turn signals when turning left are off, when off are just lite up, when right are lite up too. my wipers wont turn off which i think has something to do with the red wire i accidentally cut when pulling the engine out. Im not sure if I have something backwards or maybe a ground isnt hooked up. Im only 16 and not 100% sure if the coil wires are backwards but im not sure if this would cause this. any help is honestly appreciated because im not sure if someone took off a ground or maybe its the fact the bulkhead connected isnt probably in the car i dont know if the clips around it are a ground and that might be causing issues. I honestly know nothing lol (the picture is an older picture i know the ground to the battery isnt hooked up in it when i tried to start it is was hooked up)
