zakimodo
So far my wiring job has been very straight forward just alittle time consuming. I have ran into some issues that I am probably over thinking bit want to do right the first time.
#1. How do I wire the ignition. The ez wire kit has 1 wire that says coil +
I am running the factory mopar electronic ignition.
#2. How do I wire my door switch so that the dome light comes on when i open the door,and when I turn the dimmer switch all the way on?
#3. The alternator wiring has a charge wire and alternator exciter wire. What goes were and how does that plug into the voltage regulator?
I have a Haynes manual, but am not impressed with the wire schematics.
