the line lock goes before the prop. valve. that is the small valve next to my master cylinder. it has to go before the proportioning valve because then it will lock both front brakes and not just one.
it is a wilwood master. if you do some research you can get one from a mid 90s dakoka for alot cheaper. they came with a couple different size piston bores.
