Fast340cuda
Picked up a factory big block a body k frame for my 68 Cuda. It looked awesome in the pictures but now that I have it it looks to have been in a car that was jumped and has some major damage on the front and bottom. My plan is to cut off the factory mounts and swap them onto a clean small block k frame that I have. Upon inspection of both units I have noticed the steering box mounts on the big block frame seem to be recessed into the frame itself where the small block frame has the mount spaced off the frame. My question is do all big block k frames have the steering box mounts this way or is there a difference between manual and power steering equipped cars? The Mopar engine manual has 2 different k frame numbers listed for manual/power steering but I can't find anything that lists the differences and wondering which version I have. I will be running manual steering but need to figure out if I need to rework the steering box mount while I have the cutting wheel and welder out.
