MR4V
I have a low compression 318 with standard Carter 2 barrel & stock exhaust manifolds, 4 speed manual with 2.92 rear end.
I want to give it a bit of life without changing the factory inlet or exhaust, I have been told that a factory 340 manual cam will do that without changing the smooth idle as this is a every day ride.
I think the 340 spec is lift 430in, 444ex, dur 268in, 276ex, 114lsa.
It looks like Mopar purple factory 340 is not made anymore, I think the part number is P4452782.
Anyone know know were I can get a factory one & will this work or is it to much cam for a low compression 318?
