How do you get these things to seal? Im not having any luck with them at all.
If your talking about these they are crap. Throw them away and buy ones that you can tighten.
put A screw type clamp next to it for A few days of drivingHow do you get these things to seal? Im not having any luck with them at all.
Idk that's just a generic pic I found. The ones that broke on me was original to the vehicles. I guess age and rust weakens everything I just prefer the screw type.That clamp looks like it has been over expanded to fit the hose, based on the radius of the clamp vs. that of the hose.
Those are flat band clamps and not Corbin clamps that Mopar used for years.
I use these, on everything: radiator, fuel lines, coolant overflow hose, etc. No leaks anywhere. Use the right size hose for the fitting, and correct sized clamp, what was the issue?
Idk what they are called but I dont like them lol my slant had the round ones that was a solid piece of metal I guess that is what yall call a Corbin. I never had trouble out of them but the flat ones that look like they have been casted are the ones that broke on me. 3 of them lolThose are flat band clamps and not Corbin clamps that Mopar used for years.
Ya the late model ones are Flat band clamps. They have been used for years and I would imagine most of them are made with recycled materials from China. Lots of clamps on a car and if the manufacturers save a penny on each they save millions $$ every year. Just replace them with a Ideal brand worm style clamp and move on. You need to watch the worm clamps nowdays too. Most are **** as well. That's why I recommended Ideal brand. They are probably the best made. Ideal Tridon - Ideal TridonIdk what they are called but I dont like them lol my slant had the round ones that was a solid piece of metal I guess that is what yall call a Corbin. I never had trouble out of them but the flat ones that look like they have been casted are the ones that broke on me. 3 of them lol
Ok cool that's what I was talking about up there ^^^ that's what I thought the OP was talking about I dont guess I thought about the fact he was talking about his classic. The first thing that popped in my head was all the trouble I had out of them flat ones lol! I replaced them long ago. Thanks mike!Ya the late model ones are Flat band clamps. They have been used for years and I would imagine most of them are made with recycled materials from China. Lots of clamps on a car and if the manufacturers save a penny on each they save millions $$ every year. Just replace them with a Ideal brand worm style clamp and move on. You need to watch the worm clamps nowdays too. Most are **** as well. That's why I recommended Ideal brand. They are probably the best made. Ideal Tridon - Ideal Tridon
Nice write up!! Very good job thanks.Read this how to on hose clamp basics... Make sure that you have the clamp just behind the barb and also make sure there is some hose past the clamp...
Hose and Hose Clamp Basics
Those are actually the better of the hose clamps... They are constant tension clamps and when installed properly work best...
Those are constant diameter clamps and don't seal as well as constant tension clamps...
Exactly!Corbin clamps can work if the rubber hose is new and flexible. On an older install with a Corbin clamp, try to re-install in the same position. With an old hose and new Corbin clamp- you are asking for trouble.
