fan shroud champion rad
69DARTS
69 Darts Rule
indiana
Will a stock abody fan shroud fit the after market
champion 22 inch rad
22 inch fan shroud
if not where can I get a shroud
It will not fit. Only thing you can do is build one, unless you buy their shroud setup for an electric fan.
The factory shroud bolted right on to my Champion CC526.
Here you go
More
Is that a factory or after market repo shroud?
Hello I have a 1973 plymouth scamp 318 with a cc526 champion radiator, can you tell me the part number for the shroud you used? I am having trouble finding a shroud to fit. thank you for your time and help.
I used 2998 325. It is for drivers side top hose passenger side lower
