Does Mopar Performance make a fan shroud for the Champion MC526 22" radiator. If not, who makes one that will bolt up to this radiator that will work with a factory 7 blade fan.
I bought a repop off eBay and it fit fine for the most part. Only had to open up the mount holes a little on the shroud to get one hole to line up. Have had it a few years with no warping or anything like some say have happened. The shroud does leave a gap due to the way it mounts. The gap looks worse in the photo but it's not bad. Definitely not 1 1/2 inches. You can see the "L" bracket on the radiator where it mounts is not flush, that causes the gap, about a 1/4 inch. I've never tried to fill it in and it cools my 410 fine. 3 core champion with a Hayden hotrod fan clutch.Does Mopar Performance make a fan shroud for the Champion MC526 22" radiator. If not, who makes one that will bolt up to this radiator that will work with a factory 7 blade fan.
That particular radiator is designed to accept a factory 22" shroud (325 or 614). Physically, they'll bolt on, but the problem is the mounts are spaced so far out from the core that it leaves about an 1.5" gap between the shroud and the top tank and 1" on the bottom. In order to create a good seal, you'll need to make some sort of spacer to fill it in. As a disclaimer, this was my experience with the thinner CC526 radiator. The MC526 is about .75" thicker since it has another row, so the gap may not be as large.
What are you talking about (325 or 614) is this a partial Chrysler part #. That is what I am looking for.
Click on the link krazykuda provided. Those are the last three digits of the factory part numbers for 68-69 and 70-72 A-body 22" shrouds.
Gotcha, I will check it out. Thanks
What champion radiator do you have and what shroud did you buy,please?I bought a repop off eBay and it fit fine for the most part. Only had to open up the mount holes a little on the shroud to get one hole to line up. Have had it a few years with no warping or anything like some say have happened. The shroud does leave a gap due to the way it mounts. The gap looks worse in the photo but it's not bad. Definitely not 1 1/2 inches. You can see the "L" bracket on the radiator where it mounts is not flush, that causes the gap, about a 1/4 inch. I've never tried to fill it in and it cools my 410 fine. 3 core champion with a Hayden hotrod fan clutch.
I just dealt with all this but mine is a 3 core CC526 and it will only accept a 70 to 72 shroud. The problem I had was the pressed in nuts came right out (which by the way are metric m6) but the good part was I got these 1/4 20 fasteners and you can put them where ever you wantDoes Mopar Performance make a fan shroud for the Champion MC526 22" radiator. If not, who makes one that will bolt up to this radiator that will work with a factory 7 blade fan.
Here's a better pictureView attachment 1715069383
Can't remember what seller off ebay i got the shround from but is the "325" 1970-72 shroudWhat champion radiator do you have and what shroud did you buy,please?
The CC526 will also accept a '67 22" shroud with some creative trimming.
I'm not sure but I think the CC526 is 3 core and the MC526 is a 4 core but have the same bolt patternsI don't have the CC526. I have the MC526.
I understand. Both radiators have the same shroud mounts though.
I have decided that I'm going to take a shot at fabricating one. Just going to use some sheet metal and rivets. Since deciding a few days ago, everywhere I look I think "I can make a fan shroud out of that" yesterday it was a catch pan for hot water heaters at Lowe's..
Well...did it fit?Look at this one. Its a Spectre part # 4348. It looks good. should work and not too expensive. I am gonna try it. Bought one at Oreillys the other day and with my discount only gave $21.00 for it.
Well...did it fit?
