The fan is not doing anything at highway speeds anyway, fans are for the low speed city driving with lotsa stop and go traffic. if your having that type of issue at speed I would start looking eslewhere. First place I would look is the lower radiator hose. Is this a new install (engine, or cooling system components), if so, did you remember to put the spring back in the lower hose? There is supposed to be one in there to prevent the hose from collapsing, at highway speeds. If this is an old installation that is developing a new problem then I would say it may be that the spring has corroded away and is no longer doing it's job. If upon inspection the hose spring is intact and in place then you might consider age of the cooling system (corrosion and deposits plugging radiator, scale on inside of the block reduce's cooling system effeciancy and can cause cooling issues), pulley size (again, new install may have wrong size crank or water pump pulley or both, to fast is as bad as to slow in water flow in the world of cooling systems, although this would be a last place to check as I would feel it would be worse in city driving). Last possibility would be an aero dynamics issue in which the airflow is somehow being disrupted such that it isn't cooling at speed. Just some of the possibilities I could think of at the moment.
