So you guys got me worried so I went and pulled out the factory harness to compare all the plugs. All my plugs are the same except the crank sensor. The crank plug is the same as the oil pressure plug on the factory harness. Did you guys get any oil pressure plugs on your fast harness?
I just got my FAST kit as well and neither the crank or cam connectors fit. There is no oil pressure plug on the harness.
They sent a Chevy intake air temp sensor (p/n 307004) with my kit which doesnt fit the harness plug. You have to use a Mopar sensor. I believe the p/n is 4606487AB, but I havent bought it yet to confirm.
I'll be contacting FAST to find out what is happening.
My engine is a 2010 production line Hemi. maybe different years have different sensors?
