ElFin
I've tried a couple of times to remove the gas tank from my 67 Barracuda fastback, without any success. On my convertible, you can access the place where the filler tube goes through the trunk floor, and unscrew the rubber gasket that holds it in place. In the fastback, there is the back platform in the way. It looks like even if I remove the back carpeting, I won't be able to get at the gasket. Have any of you ever had to do this job?:???:
