Dartn440
Wondering if the hole for this toggle switch is stock to a 74 and if so what it's for
Map light maybe, but my 74 has a switch there that went to a rear defrost unit mounted in trunk.
What did the manifolds come off of, defiantly smog ones, with the holes below the ports.
They may need plugged on the back side, usually smog manifolds had a AIR set up on them.
Hey now! Scored these 360 manifolds and they are inbound. The hard core speed shop dudes and guys I respect from FABO say they will work with a little nip and tuck....
I was wondering what is the right wiper motor for our Duster. Did they use both 2 and 3 speed motors in Dusters for 74? The switch has got to be different for 2 and 3 speed motors right?
