1. We haven't used the SMP RU-11 Resistor for nearly 4 years?
2. Alot of failures??? Where are you getting your information?
FACT: We've had 18 component failures in 6 years and over 5,000 units in service world wide, that's a .0036% failure rate and we've warranteed every one of them INCLUDING paying the frieght back to the customer.
3. HEI Modules? Bring it on! I'll show you on our test bench how the FBO Systems "Outdated ECU" will run circles around your "Partstore" $30.00 HEI module in RPM and Output....it's not even a contest.
4. Stranded on the side of the road?
Any parts store ECU will get you home, won't run real good but it'll always get you home, so When, not If, so When your MSD fails keep your AAA card handy. Any stock type replacement part will work on the FBO Ignition System it won't perform to perfection but it'll keep you off the back of Bubba's hauler.
You guy's find me any ignition system that will run to 8000 RPM, maintain out put levels in the 34-38KV range, install in 20 minutes, not retard the timing to 8000 RPM, failure rate of less than .004% and cost less than $130.00 including the Cap and Rotor.....I'll Buy It and install it on my car!
FYI....At the Division 6 Finals last month the Final Round pair of Pro Bracket Cars in the Big Money Cash Bash were both running FBO Ignition and FBO/ETS Carburetors and the loser wasn't a Mopar, so we know who took home all the money
http://www.4secondsflat.com/fbo__et_slayer_carburetors.htm
See the big winner and read his story at the bottom of the page.
A 10 flat Race Car running a $129.00 ignition system and winning continuously!
