Snake
Mopar Nut
Hi guys,I would like to install my Dart badges on my left and right front fenders now.when the body guy did his thing he couvered over thoes holes with filler or high solid primer.So I cant see were the holes are.If I look on the inside of the fenders there is something push through.what could I use to push that out from behind enough so i could poke the holes clean to install the badges,bear in mind there is not much room to slide my hand between the door and fender.Thanks,someone mush of had this issue befor.
