73-74 are slightly different than 75-76. I believe that is a 75-76 as it has holes for mounting a front bumper filler. Also some slight differences in the grill mount area. If it is not rotten and is reasonably straight it should be worth $100 - it can be made to work on 73-76 Dart and Dart Sports, as well as 67-69 Darts by changing the side marker location and hole, and using the headlight buckets off the fender it replaces.
