Fender tag decode help
jasonhensley
Active Member
New Tazewell, TN.
Hi guys, I'm new to the forum and need to know what would be the best place on here to get help decoding my fender tag. I can make out most of the letters and numbers just don't know what they mean. Help:prayer:
This may not be 100% accurate...but it's a start
VN23:
Plymouth Valiant,Duster
Unknown
2 Door Hardtop
C2R: 225 110HP(net) 1-1BBL 6 CYL
1972
Windsor, ONT, CAN
102099: Sequence number
1E44: Unknown
D34: Light Duty Automatic Transmission
T83: Unknown Exterior Color
F385: Trim - Luxury, Cloth/Vinyl Bench Seat, Unknown Color
GB5: Bright Blue Poly Int. Door Frames
806: Build Date: August 06
116657: Order number
V1X: Full Vinyl Top, Black
U22: Unknown
G31: OS RH Manual Standard Mirror
L31: Hood/Fender Mounted Turn Signals
M21: Roof drip rail moldings
M25: Wide sill moldings
M31: Belt Moldings
M88: Decklid Moldings Treatment
R11: Radio Solid State AM (2 Watts)
END: End of Sales Codes
OK, there are a couple discrepencies in your post, as you have already discerned!! First, I think the "C" in your VIN line may be a "G", as the E44 is coded as a 318 2 bbl. Next, the body color I believe is notT83, but TB3, making it Basin Street Blue, the color it is wearing in the pic!!
Next would be the interior trim color, F385 as posted. I believe that this should be F3B5, which would be a B5 blue interior, which I'd bet it has!!
The "U" code in the book is tires, but there is no U22, so I'm no help there!! I think Furious has the rest covered for you. Hope this helps, Geof
Love you guys. You are all so cool. It's hard to read a rusty old fender tag. Sure some of you all have been there a time or two.:cheers::newb:
VN23:
2 Door Hardtop
G2R: 318 150HP(net) or 155HP(net) 1-2BBL 8 CYL
1972
Windsor, ONT, CAN
E44: 318 cid 2 barrel V8 230hp
TB3: Blue Streak (Dodge), Basin Street Blue (Plymouth) Exterior Color
F3B5: Trim - Luxury, Cloth/Vinyl Bench Seat, Blue
GB5: Bright Blue Metallic (Dodge), True Blue Metallic (Plymouth, Chrysler, Imperial) Int. Door Frames
U22: Unknown
M31: Belt Moldings
There should be a space between the U & 22;
U - Build for US sale
22 - 22" radiator
