Fender well exhaust routing
twayne24365
Maryland
My dart is down at the exhaust shop getting the exhaust put on, keeping frame connectors in mind there is not many options on routing the exhaust, I'm using 3.5-3" collector reducers into flow master super 10s. anyone with a big block a body with fender well headers mind showing how your exhaust is routed?
Made my own connections plates to 3 inch, no mufflers, used steel wool at the end of the pipe and capped it with baffle steel
Mine was done years ago. Had the shop turn the exhaust back in to somewhat stock configuration as I wanted it to exit in the stock location.
