I noticed this a few weeks ago and had front wheel clearance issues on my 73 w 2" primary fender well units myself. Yes you can keep the 15" front wheels just go w/a lower profile. We seem to like our skinny fronts & a majority end up w the "skinny" 165's on them usually 80's an actual 165 80 r 15 is over 26" tall. They will rub slighty on deep turns esp. the right turns. So I went to another car (that I had) and found a pair of 165 /65/r 15's. I measured them .... Same damn height... Go figure. I went to the tire store and we ran a tape on a couple of brands. Geeze these tire mfg's are like Jean mfg's these days. Some aren't that accurate. I ended up with 185 55 r 15's to make sure. I may have over did it a bit. I plan on pulling the front wheels off the ground, so I went small. These are only 70$ a pc and still rated at @ 130 mphWhat am I looking at for front wheel/tire combo? Will "mostly" be at the track? Remember the part# for the Hedman fenderwells?
I have the 155 r 15Any front tire issues with a 2" fenderwell header on a '69 Dart. Transitioning from early A SB to the 69 BB Dart. The early A has some clearance issues with front tires and that's with a 1 5/8 header. More room with a '69?
I had to pull out the magnifying glass they are Ironman tiresCan you list the brand and part number for the tires please.
Ironman Imovegen2 1855515 82v893682 56.00 a pc. 30 install etc. I had the ol' Cragar supertricks 2 pc (leaking) so I went w/ tubes(3np37). I'm using a slightly narrower wheel than recommended they are probably 5"min tires. I used them since they were cheap and convenient. Robertson tires. You can order a better (low profile tire) It would have to be ordered. They jump up in $ drastically from here.Can you list the brand and part number for the tires please.
