Have had a sniper for a couple years. Definitely had a learning period. I’d suggest shielding all wires, rfi is a big issue. I did have a bad ecu that was replaced under warranty, but took a while to get Holley to get off the “it’s installation errors” mentality. Went without timing control till it was running good, just added that this year. Still learning timing tuning but it’s make a change, if it doesn’t work reload the previous tune, takes 10 seconds. It does start/run better but it’s definitely not plug and play.
